Vengeance
Updated 7/19/2013 : Replaced the O2 sensor, bad vacuum line, and coolant temp sensor and it was abble to pass.
SO i unfortunately failed a cali smog. I was wondering if you fine individuals could help me identify my problems.
Here's the test results:
______________________________________________________________
%CO2 | %O2 | HC(ppm) ------| CO (%) -----------| NO (ppm)
11.97 | 3.37 | Max=59 Me=65 | Max=0.34 Me=0.03 | Max=484 Me=771-------- 15mph
11.70 | 3.75 | Max=34 Me=42 | Max=0.32 Me=0.01 | Max=498 Me=768 --------25mph
Sooooo as you can see the HC and NO are the two that are killing me here.
The guy at the shop recommended i replace the upstream O2 sensors since they are original. And retest from there, but i don't want to chance it so what else should i check.
I have already replaced: Distributor, plugs, wires when i bought the car last year. The timing is set to B10*....and no CELs
The only issue i find with my car is it takes forever to warm up, i will drive for 15min and the needle will only be at the N on Normal. so could i have a t-stat problem causing the car to run wrong?? maybe??? Do i possibly have a poor operating EGR valve that is not setting off the CEL.
Oh and one other problem i have is that when i drive the car cold the car does not like to rev past 2200-2800rpm, it stutters or sputters or something, but as the car engine warms up this problems goes away?
