eeltam
1st test
After the first test I replaced plugs, wires, ran sea foam, cleaned the egr and even added a little acetone to the gas. As you can see both hc readings went up and NOX came down.I had a friend check the cats with his laser thermometer and all four cats had a cooler reading at the output than the input. Now I believe this indicates bad cats. There is no way I can afford all four. I don't make much money. Two is gonna be very tough to do. is it possible to pass with just two good cats? Will the cheap universals suffice? Also, what exactly is the difference between obd1 and obdii cats.Any suggestions are welcome.Thx
2nd test | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
