sanchezcruz_20
- Joined
- Mar 13, 2007
- Messages
- 233
- Reaction score
- 0
Went to the track tonight. Basically my first time ever. Each run got better...... I LEARNED A LOT!!!!!
Just a little misc. info:
The temperature when I got there was in the 90's and even when I left after the sun was starting to set it was still 80's. I don't know if temp. really matters all that much, but I know some of you guys mention it when discussing track times.
On arrival, there was a slight sprinkle of rain which eventually led to a delay in the track proceedings. After a bit, the sun came out, the dryers went up and down the track a few times and we were under way. Obviously, the humidity was very high.
Right now I'm running on 245/45/16 Fuzion ZRI street tires. They're cheapo and DON'T hook well at all. They came with the car. I also didn't realize that my tire pressure was at 45lbs until after the 2nd run. I just never bothered to check the tire pressure before, never had a reason.
1st run:
60ft: 2.64
1/4: 16.05
MPH: 93.76
:hammer: Yeah, I know.... it sucks REAL bad. Like I said, I was a first timer. I roasted the tires off the line, spun clear through second and even into third. The ass end of the car was all over the track. I had to let off the gas to get a hold of it. I didn't realize until my 3rd run (after talking to a fellow Mustang owner) that cars with street tires shouldn't drive through the water. So I had no traction whatsoever, like I said the car was spinning into third gear. The track was also just a tad bit wet because this run was before the delay.
2nd run:
60ft: 2.29
1/4: 14.60
MPH: 95.72
Obviously a big improvement over the first attempt. Still spinning through first, but got a little better traction in second.
3rd run:
60ft: 2.23
1/4: 14.39
MPH: 96.39
Getting better. Didn't drive through the water and also reduced tire pressure to 30lbs. Babied it out of the hole, basically got traction the whole way.
4th run:
60ft: 2.25
1/4: 14.33
MPH: 96.97
Same as before, with decent traction. Though I did powershift from 3rd to 4th.....
Overall, I learned a lot about driving down the 1/4 mile track and had a BLAST! Can't wait to go again with better tires (thinking Nitto's or BF Goodrich KDW's)!
1st run:
60ft: 2.64
1/4: 16.05
MPH: 93.76
2nd run:
60ft: 2.29
1/4: 14.60
MPH: 95.72
3rd run:
60ft: 2.23
1/4: 14.39
MPH: 96.39
4th run:
60ft: 2.25
1/4: 14.33
MPH: 96.97
