Fox BBK X-Pipe On 95
ivan12
I went to Tijuana, Mexico today to take my dad to the airport. Long Story short there's a hole in my X-pipe after going over a monstrous speed bump. I would rather not repair it since it's not a very well made unit and I'm low on car funds. A local guy has a new BBK Fox X-pipe for cheap, will
it fit? What kind of problems can I get into?
I would advise against it, but then again i had a bad experience with trying to fit fox exhaust parts to my car. someone else might have had better luck but I'm pretty sure they are different.
RossA81
Monkton, MD
It might work but the hangers are different. At minimum you will need to cut the hangers off. I am not sure if the air tube will line up or not.
Ross
wayne94mustang
I run a fox H pipe on my 94, only because I got sent the wrong thing and didn't know better at the time.
I do not use the hangers on the H pipe so that's a non issue for me, but I did have to lengthen the crossover pipe.
Since the crossover pipe needed to be lengthened i highly doubt a X pipe would work.
Lee12609
i'm running a fox X pipe, no issues, but i'm auto. the dimensions are nearly identical, but i think the flange angle is different a hair different. mine is a 2 piece UPR X, not the 3 piece pypes style and like i said fit like it was made for it.
ivan12
ivan12
I really don't want to risk it and have it not fit as I don't have much time to work on the car right now. Can you guys recommend an affordable off road x-pipe? I really don't want to get like a $400 magnaflow off road X. What do you guys think of UPR brand x pipe? I can get one shipped for $160
blkmcnasty
Illinois
If you are low on funds just get a summit o/r h for $114 to cruise around with. Then save your money to get the full bassani exhaust that you really want!
Mr.Bolt-on
Haha, that's what I was thinking... the summit pipes, because $400 dollars is just way too much for X-pipes... Mufflers and X/H pipes... they all do the same thing. IMO mufflers that go for more than $60 bucks a piece are too expensive. Of course I probably paid more for than that for mine... Actually I know I did... uuuggghhh...
