Fox timing chain cover,wp and accys?
revkvn
I have access to a complete set up from a 95 GT, but I'm running a carb, with a mechanical fuel pump, for motor, and an electric for the juice, so I have to use a fox cover with the fuel pump boss in the t-cover. Will the rest, less a/c,smog pulleys and brackets work with the electric fan set up? If so ho much room do you have using the w/p with serp. belt from the radiator?
ryclef331
I have no idea what you're asking. You can't run the sn95 timing as you said b/c you need to run a mech fuel pump. You don't want a/c, smog, or the brackets...so what benefit are you trying to get from the sn95 setup? the added space between the rad and pulleys?
Paul
It seems to me that the internet has destroyed the ability of America's youth to form cogent thoughts and complete, grammatically correct sentences.
Paul.
R
revkvn
What I'm asking is this..... will a fox timing cover, with a fox waterpump,alternator and bracket, tensioner pulley, and power steering pump and bracket(s) physically fit in an SN95 car.Will there be room to keep the electric fan on the back of the radiator.
Using a mechanical fuel pump with my combination,I have to use a fox body t-cover, because that is the only cover that has a provision for this type of fuel pump.
Schiffy
Norfolk, Va
you cannot use a fox water pump on an SN95 5.0 car, so i'm going to go with no, you cannot do whatever it is you're asking. Paul, I'm america's youth, and bad grammar is a pet peeve of mine, though i slip sometimes too. BUT, i get what you're saying...
Paul
Yes, if you swap everything it should fit just fine. Why don't you just switch to an electric fuel pump? Seems to me that would be much easier.
Paul.
ryclef331
He CAN if swaps the timing cover as well. A pet peeve of mine is misinformation. <;)
AfghaniBob
I see that our public school system has not stressed capitalizing America. Slip all that you want on grammar just capitalize the name of our great country. All though it would have been worse had you misspelled America.
On topic, change the whole front setup from the cover to the pulleys over and you should be fine.
