Front Wheels Sticking OUT!!!!
94white5.0gt
:wall: just put my new DD cobra r's on my 94, 17x9 255/40, 17x10.5 315/35, and the backs fit good, but the fronts stick out about an inch. i've been looking at pictures of cars on this site and everyone's wheels fit fine???? i still have to put my pro-kit in, will that make them come in at all???
ReplicaR
That's pretty much normal. Mustang front end does not exactly house wide wheels as say camaro for example. On the camaro you can run 315s in front with out them sticking out from under the fender. On the mustang, 275 seems like too much
94white5.0gt
Downshift
Mine sticks out too. Would not bother me as much if the backs were out instead of sunk in to the wheel well...
I think it looks good.
now get the rear's out there :thumb:
Ciotti
Dial in some negative camber and it will tuck the tops of those tires in like mine...
I run 2 degrees negative camber because I autocross the car 2 to 3 times per month, for you that may be a bit much so I'd say try 1 degree negative camber may be just enough to pull the top of the tire in just enough. Plus it will handle a hell of a lot better that way :)
My pass. side looks worst than yours, i think its a normal thing on our 94's tho. :dunno:
Also, ciotti is right you wanna have your camber @ 1- 1.4 it rides so good its unbeliable
My camber is 1.4 Driver side and 1.2 pass. side.
STR33TR
Did Ciotti write anything? I couldn't pay attention b/c of the clip of the cute Lindsay Lohan.
mmmmmmm........ jiggle..............
Ciotti
THE TEXT IS OVER HERE TO THE RIGHT!!!!!! OVER HERE!!!!!! STOP LOOKING AT THE JUBBLIES AND LOOK OVER HERE FOR THE TEXT!!!! Ahh screw the text, I'm going home to squeeze my girl's DD's :happydrunks:
Srchop16
