fuel line is leaking
CH302K
I have a 95 gt.It sat for five years and now I have time to make it run.The gas tank was funked up and everything in it.I replaced everything.I tried to start it but I smelled fuel.I got out and did a walk around.lots of gas on the ground at the rear.I dropped the tank and had a friend turn the key on.The supply line is leaking.Do I need to replace the fuel line?
Thanks
99GreenStang
My suggestion is if the line is leaking and you see it leaking . Replace it .
RichV
CO
Where is the leak? Usually the only things to replace are the connectors and retainers.
Is it at the tank exit? Is it supply or return line? Is it at a connector?
99GreenStang
Also just so you know they make special line removal tools for the AC and Fuel lines on these cars . You can buy the set of tools at most auto parts stores for around 10 bucks .
C
CH302K
Where the supply line pushes on the hat.It feels loose where the return line is tight.
C
CH302K
I have the tools and it came right off but was loose.
408SUPERSNAKE
