Wmac
Steeltown, Ontario
For a T-45, use this chart. For a 4r70w trans, you'll need a speed calibrator.
J
JLS-SN95
Rochester NY
I'm new to all this, so I'm trying to understand this chart and what I need. I have the T45 5s speed transmission, current gear ratio is 3.27, I want to go to 3.73. Is this telling me I only need to change the gear in the dash?
Wmac
Steeltown, Ontario
No, since you have a T-45 with an 8 tooth drive gear, only the driven gear needs to be changed. It's on the vss, which goes into the trans. If you have a "stock" size tire like a 245/45/17, then the formula would be: 8x3.73x812/1000=24.23
The only gear that is close, is a 23 tooth. Try LMR or CJ Pony.
J
JLS-SN95
Rochester NY
MUCH THX!!!!
SPeace-ATL
CAUTION!!!
For a 96-98 GT T-45 the internal gear is the 8-tooth which is only good for calibration up to a 3.27 differential with nominal tires.
A 3.55 or 3.73 or 4.10 will require a Speed Calibration Device to be installed to get the speedometer accurate.
The references to any speedometer "driven" gear on the VSS with more teeth than 21 are all aftermarket gears that will work, but only for a few months before it chews off all the teeth.
These 23 tooth gears referenced above will also eventually ruin the internal speedometer gear rendering the speedometer drive useless until the gear is replaced inside the transmission.
The 23t gears mentioned are TRASH. I have a collection of them in my junk bin that I have removed from transmissions over the years. They should not even be offered... The gear teeth have to be paper thin to get 23 teeth around the gear. No GOOD!
The 96-98 COBRA T-45 has a 7-t internal gear that will calibrate up to the 3.73 differential without a Speed Calibration Device. If you can get your hands on a 7-t internal gear the transmission tail section still has to be opened in order to install it.
For Reference, the 1999-2001 T-45 transmissions have an electronic "OSS" speedometer pickup. Those are calibrated electronically in the programming of the "tune" of the ECM.
Stan
Daryl
Somis, CA
LMR.com
Click in your year
Search: rear gears
Click on 3.73’s
Scroll down to links for driven gears and speedometer gear corrections
Wmac
Steeltown, Ontario
Stan:
We are fortunate to have someone with your manual trans knowledge share your opinion. I sure do appreciate when you take the time to comment.
If anyone was considering changing an 8 tooth drive gear, wouldn't a 6 tooth (black) gear be a better option? Then they could use a Ford driven gear up to 4.30 rear gear.
That's what I did when I swapped to a T5 last year with 4.10 gears. A 20 tooth driven gear is close to actual speed.
GTamas
Austria
CAUTION!!!
Stan
What's the situation with T5 in a '94 GT? Up to which tooth count driven gear is it safe to use, without changing the internal gear?
Wmac
Steeltown, Ontario
See chart above.
Your T5 will have an 8 tooth drive gear. 21 tooth for 3.27 gears or 23 tooth for 3.55 gears. Or use a speed calibrator.
SPeace-ATL
Yes, the ABBOT should be able to recalibrate the speedometer. Just know not to use a gear on the VSS with more than 21 teeth or the gears will tend to disintegrate.
Mikehonco69
