got my new rims
red94gt5.0
17X9's for front 17X10.5's for rear, i think im gonna have clearance issues, i put the 9's on the back and it was really tight, are yall running spacers? for those running 10.5s that is, its a 94 gt. i would love to do some 315's on the back :D just saw some on a notch and they looked sikk, gimme some input cuz im buying tires friday
95PGTTech
315/35/17. Have run Sumitomo in that size, BFG DR, and Nitto 555R. didn't need to roll fenders or bang out inner fenderwell (in fact the tires are still not flush with the fender...needs to be wider for my taste). just flipped the quad shocks. and I'm lowered 1.5"
R
red94gt5.0
that damn sure answers my question, what can i do to make it stick out a lil more, cuz i like the slightly outside the fenderwell look myself, whats flipping the quad shocks do?
see the shocks that goes side to side, from behind the rear of the brake dust shield to the body, unbolt it and flip it thats it.
95PGTTech
gives more clearance for the tire. if you don't flip it, you probably won't clear those new tires. the fat part of the strut sits right where the tire does. when you flip it now the skinny part is next to the tire
DSTRBD
Remember if its as issue just keep it off... what wheels did you get ?
R
red94gt5.0
black cobra r deep dishes for back and regular black cobra r 9's up front 10.5's in back, i wanna go crazy wide in rear to give it a mean staggered stance, 315's are going on rear but not sure what would match them up pretty well up front, need to know a front tire size, any input?
Sn95Willis
Baytown Tx
Correct me if I am wrong but to properly get rid of the quad shock you must get some Aftermarket lower control arm... Or you will have some wheel hop back there..
GDawg
Some good information here...
I'm going to change over to a 10.5 rear wheel and then am looking at putting in some adjustable LCAs. Is there any benefit to replacing the UCAs?
CanaryGT
Phoenix
Ive heard that if you get good LCA there is no point in the UCA. In fact, I heard something about the binding issue between having the polyurethane Uppers and Lowers. And Yes I would just ditch the Quads and buy some good LCA's. Even if you had your Quads on with stock LCA's you would suffer wheel hop.
Silver281GT said:
Hey Javi do you have spacer on the rear??
No, i run 295's outback.
CanaryGT said:
Just a question, why wouldnt you just get rid of the Quad shock?
yes.
Get some nice MMLCA's.
like so:
actually MM recommend FRPP UCA's the bushings are stiffer and improves handling, some other arms/design have bending issues.
depending on whats the offset on the rims, you might have to beat up the inner fender well.
