drivers side there is large rubber grommet that all the stock wires go through. There is enough space in the rubber to poke a hole in it and run your wire through it. Poke a screw driver through it, then feed the wire in.
sometimes there is not enough bass out of it after swapping decks, not a hard problem to solve if that is the case.
The Mach 460 sounds a lot better with the new head unit . I guess it kinda helps my alpine has a built in eq u can tweak everything ..
i have apioneer deck hooked up to the 460 harness. i couldnt hear anything.
the previous owner hacked up the 460 wiring. just disconnected the front amp and spliced into those wires. it was a rat's nest. i can hear it but its definitely not quality. since i got the HP out of the way, im ripping out the whole 460 system for a 4 channel amp. i bought speakers from joekd eons ago. infinity kappas. im finally installing them with a memphis audio 4 channel. i'll just use it as a 2 channel. i can hear the front speakers quite crisply.
