Headlight Issues
zneilsen
Having headlight issues with a recently purchased '95 Ford Mustang. I can flash my high beams and the indicators work perfectly. My dash also lights up as it should. I cannot figure out how to turn on my low beams or fog lamps. So far, I have replaced the bulbs, checked the fuses, and replaced a heavily burnt out headlight switch pigtail connector (pic attached) with no change in outcome. Any ideas on what else I can try? All are incredibly appreciated! Thanks.
now by "all" do you mean you checked the fuses that were listed one or two in the manual that mention the headlights, or did you literally check every fuse in the box? When I say check all the fuses, I mean every one in both box. It honestly takes less time to get on your back and pull/inspect each one than it does to get out the manual and try to figure out which one you think/hope is the one. You would also be surprised how often when you find a blown fuse and check what the manual says it powers and it has nothing to do with the problem at hand. When I suspect a fuse I just start pulling/checking and if it is a fuse it is found in a few minutes.
94IndyPace
No disrespect. Are you pulling the knob out 2 clicks. First is for running lights and second is for your headlights. If you are, I would check power leaving the switch that it is good also. Or if you even have power
Alexi
Canada
Since you’ve already tackled bulbs, fuses, and the pigtail, the next likely culprits are the headlight switch itself or the multi-function switch (stalk on the column). Test the headlight switch with a multimeter for power output when turned to low beams if it’s dead, replace it. If the switch checks out, the multi-function switch could be faulty, especially if it’s original. Also, trace the wiring from the switch to the headlights for any breaks or corrosion. A test light or voltmeter will help pinpoint where the signal drops. If all else fails, the relay (if equipped) or a bad ground might be the issue.
Z
zneilsen
Yeahh, I tested all fuses with a test light and then verified by pulling all of them out and examining. Unfortunately it's more than a fuse problem... thank you for the help though!
Z
zneilsen
I have tried that... I wish that was the case though!! Going to try checking the power from the switch next. Appreciate it!
Z
zneilsen
Appreciate this! I actually replaced the headlight switch with the pigtail. Going to give the multi-function switch a look, though I'm thinking it's likely going to be wiring as the indicators and wipers still work nominally. Any tips on best practices for tracing the wiring? Found it pretty difficult the first time I tried...
you should be able to test the voltage into the multifunction switch and verify if it sends it out or not. There is a lot going on in that little sucker so it isn't hard to believe one died and the others still work.
Alexi
Canada
Since the indicators and wipers work, wiring is a likely culprit. Start by checking for continuity in the headlight circuit focus on ground points and connectors near the multi-function switch. A test light or multimeter helps. Look for corrosion, loose pins, or frayed wires, especially where the harness bends. Take it slow and methodically it’s tedious but pays off.
