Heads for X or Z cam.
musclemustang94
I have an F-cam but the X and Z are bigger. I dont mind a rough idle (i like it actually) what would be a good set up for an X or Z cam? My car is eventually just going to get driven to the track and back and im hoping to put a motor in it this winter. Something semi-streetable with lots of mid and top end power.
Spd0lit
SoCal
Well those cams are a little over board for what you have in mind. :hammer: But if you want crazy mid and top go with a built 306 and a really high flowing head (Maybe a AFR 185 might do?) of your choice upgrade the valvetrain like valve spings and such. Then go rev to the moon if you want assumming you are keeping it N/A.
musclemustang94
I said semi-streetable. Meaning....I will drive it on the street very seldomly and it will be mostly a strip car.
Mr. OAM
The X cam has 2* less duration than what you have now and the Z cam has only 2* more duration, but both cams have another 30-40 thousandths lift. Don't expect much, if any, of an idle change. Also you would be going from 114* LCA to 112* LCA. This means that the idle quality will change just a tad (perhaps not perceptable) and your engine's power ratings will peak a little more and not have as flat curves, but not as peaky as say a cam with 108* LCA.
I don't think you are going to get what you want out of these cams. If you are looking for something that is made for mid and upper RPM power you should be looking at cams with longer duration, like 240* @ .050" or more. Also, if you are going to go for a high reving engine with top end power you will need to put in higher compression pistons to go with the longer duration cam. As you go longer in duration you bleed off compression and the engine becomes a dog. You need higher compression pistons to make up for this.
When you go with this longer duration cam you will also need an induction system that can feed the hungry cylinders quickly. This means matching everything else to your engine.
Without going into great detail, you cannot just put a "big" cam into your engine, even with replacing the heads, without also upgrading the intake, fuel delivery system, exhaust, torque converter if applicable, and rear gears, as well as a few other things. Is all this in your budget? Is this the kind of car you are looking to build?
Steve
musclemustang94
Yes I knew all of that. Its going to be street/strip car heavy on the strip. I'm planning on switching to a carb. Its going to be an old school style hot rod in new school clothes. Its going to have a high compression, high rpm, big headed, carburated, big cam small block in it. I like the simplicity of the old school engines. I may set it up with a junkyard turbo set up or something I dnno. I'm just doing research right now i guess. Thanx for the info by the way, great information.
Suspect
ATL
fcam is good for a turbo. so keep it if u gonna run that. but u also said ur building high comp?! not so good for power adder unless u plan on keeping the boost really low. either way good luck and keep us updated on what u do.
:thumb:
