heads
i_love_my_stang
im researcing about new heads, i've decided which ones to go with but i was wondering what i all need with getting new heads, hardened push rods, new gaskets, valve covers, i was wondering if i need to get a new rocker assy? the heads come complete valves, springs, i dont know if i need a different rocker or what. ill be getting new head bolts as well anything im missing?
LAFENATU
First of all, what heads are you going with?
You can buy a kit with all the gaskets etc from Summit for like ~$80-$100.
No you don't need new valve covers, you use the originals. You don't NEED a new set of rockers but it would improve your power.
stang94X
which heads are you getting? are they for pedestal or stud mount rockers? youll have to get rockers if the heads are for stud mount, but if theyre pedestal mount then you can use the stock rockers but i would get roller rockers anyways. you dont need new pushrods unless you get the trickflow heads but its always good to be safe and get new ones anyways. valve covers are needed if you get roller rockers, well or you can cut the oil baffle out of the stock cover and run 1.6 roller rockers but have to get a higher cover if you get 1.7/1.72's. new head bolts, heads gaskets, intake gaskets, header gaskets are a must, new intake bolts if you think they need replaced, and i cant remember anything else right now
LAFENATU
That's why it would be much easier for us to find out what he is getting first..lol
LAFENATU
i_love_my_stang said:
lol sorry im getting the dart iron eagle ones
For a stock engine?? These heads are geared more for a built 302/331/347.
Your going to have a cam to go with them, if you keep the stock cam those heads are going to be worthless, as well as an intake.
You might want to consider a different set of heads. AFR 165/185, TFS TW, Edelbrock Performer/Performer RPM.
I
i_love_my_stang
oh really, humm thanks for that, if not them i was going to go edelbrock, are they pedistal or stud, which would be the best rocker to get with them?
LAFENATU
You can get the AFR 165/185 or the Edelbrock Performer in Pedestal mount, which is your stock version.
Pedestal is going to be the easiest rocker to go with, the only downfall is the farthest I would go with a pedestal mount is around 450-500HP. If you plan on making any more power, I would look at a stud mount.
I
i_love_my_stang
ya i only plan on going to that much, i plan on re-building a 68 fastback which ill really go all out with, the 94 is still my dd so i think 450-500 hp should do just fine thanks for the help
LAFENATU
Personally I would do the AFR 165.
The Edelbrock Performer head is also a nice head.
I
i_love_my_stang
ya i can get a deal on the edelbrock so thats why im going that route, would you keep the stock valve train or no? also what would be a good cam to go with that head
LAFENATU
The E Cam is a good cam with those heads, the stock cam is fine too. The stock cam is not a horrible cam by any means. The difference in a stock cam and an aftermarket is probably .2/10 - .3/10 in the 1/4 mile. Has the best drivability hands down.
I would do the heads and a set of 1.7 rockers and have fun. Do an intake manifold when money permits.
.02
I
i_love_my_stang
cool thanks, wasnt looking forward to trying a cam right now in my garage anyways lol and if its only that much i dont really car then, ya manifold is after heads :D thanks for the help, does edelbrock maker rockers as well?
94kingcbra
get some scorpion rockers, I have 1:6 rockers with a stud mounted girdle on my afr 165's. It works great together with with the E 303 cam on a 347 stroker. Hell, it passed smog in CA first try!
