heater warning light
oz95gt
Bathurst NSW Australia
G'day from Ozzie I have a 95 GT (very rare this side of the pond) just after some info on the heat warning
light on the dash that is staying on , any help would be great. With regards Mick
evilcw311
Most Evil Member!
Louisville, KY
Heater warning light?? I’m guessing your talking about the coolant/overheating light???
oz95gt
oz95gt
thanks for the reply but no it looked like a cat converter with heat written under it funny thing is i just went out to take pic for you but its fixed itself and gone
I was confused on this as well and wasn't even sure how to respond. Get a pic next time you see it for sure.
evilcw311
Most Evil Member!
Louisville, KY
Never seen that light before. Must be an export thing.
01yellercobra
Things like that generally don't fix themselves. Maybe it's a warning for a cat overtemp. If that's the case I would pull the exhaust and look things over.
white95
Apex Junky
Admin
Prairieville, LA
Did some digging for you. In the US market cars, we have a low coolant light in that spot. You need to check your coolant level. If it’s good, the sensor in the overflow tank is failing or has failed. Hope this helps.
