Hellwig rear sway bar question
PinkieT
Cleveland
Met a guy to buy some other parts and he has a Hellwig 1" diameter aftermarket rear sway bar he wants to sell too. https://www.summitracing.com/parts/hel-6801/overview/year/1998/make/ford/model/mustang.
I'm running a 98 GT ragtop. It has Cobra brakes, Koni STR.T struts and shocks, tubular upper and lower rear control arms, subframe connectors, front strut and rear shock braces. It is a cruiser. Would the Hellwig be too stiff for my ride? If not, will it work OK with the factory front sway bar or should I upgrade that too if I do the Hellwig rear?
PinkieT
PinkieT
Cleveland
Good article. Might unbalance my car unless I buy the matching front sway bar, right?
white95
Apex Junky
Admin
Prairieville, LA
I wouldn't upgrade the sway bars until you get the rest of the suspension where you want it. That way, you can 'fine tune' over/under steer.
