Help installing o/r h pipe
justinschmidt1
So if I get a off road h pipe I heard no shops will install it becuase its illegal or something?...So the part where it connects to the headers will be just bolt on..but how can I make it so it will bolt on to the mufflers?...
IEC Stang
at the end of your existing h or whatever u have there should be 4 bolts u take off. so 4 bolts up front by the headers and 4 bolts where your h pipe ends :)
J
justinschmidt1
Its welded at the end of the current pipe...thats the problem..is there any thing I can do? I dont have any access to welding
scarface
Guest
got to a muffler shop, or get new pipes that go between the Hpipe and the mufflers
ALITL8
where did you get this h pipe? got pics?
i just paid $169 plus shipping for a brand new BBK x pipe from Texas Hot Rod. you may just want to purchase a new one thats easy to bolt up if the muffler shops in your area wont work on them :dunno:
J
justinschmidt1
I plain on buying a mac off road h pipe...it has the 4 bolts at the end.where it meets the mufflers...but Im not sure If I will be able to just cut the pipe and connect it or do I need some adapter..like where it meets the header it goes big to small.
J
justinschmidt1
umm...I have mac/lt headers...to like straight catted pipes then to welded on flow masters
The problem is that its welded at the mufflers...would I be able to cut that and attatch the new pipe..without welding?
Willis_98GT
DFW Texas
your going to have to cut it and have it rewelded... its not that expensive to do. if you know a buddy with a wire feed... or a muffler shop will prob do it for like twenty dollars or something.
scarface
Guest
if you swell the pipes to fit over the existing pipes. You have a custom exhaust system. to make it bolt on, you will most likly have to replace everything from the header flange back.
scarface
Guest
muffler shop wont touch Non catalyst systems.
Willis_98GT
DFW Texas
come to texas bro. >:D
IEC Stang
if your mufflers are welded to your catted h and u want to replace the catted h with o/r h then your screwed sry to say but what u want done can't be done without some welding involved. If it is at all possible to find someone that has a welder maybe u could ask them if u could use it. U could also tell them that u would give them some money for it too. If u can't get a hold of a welder u won't be able to switch to an o/r h unless u find a muffler shop that will do it for u but that would be hard to do.
scarface
Guest
how about a pic of what you are working with? you may be abe to cut the old setup off and have the muffler ends swelled out. THen you could slip them over the old pipe and run a new catback from there.
