Help Rattle probelm!!!!!!!!
Demolisher
Ok once the car is hot and i step on it and the car is about the shift i hear like a pipe loose or somehting rattleing against something else my thoguht is its the drive shaft hitting the 2 chamber flows but idk and im getting tired of it cuz when im racing once the engine gets hot it does IT! :nonono: i thought it might of been the pipe hagin from my car thats attached to the smog but i took it off and it still does it just not as loud plz help :help2:
FASTANG
Check your exhaust clamps. I found one of mine was hitting the upper
control arm under load, causing a nasty rattle. You just have to get
under there and look at all the possible causes. It just takes patitence.....
Demolisher
ok well do ill probaly take it to a muffler shop and tell them to checkthe clamp whre the headers connect to the piping ;)
Suspect
ATL
:mad: yea i had that problem. mine was where it went over the axle it would hit the frame or the uca. got some new clamps and now it dont move.
