help undecided
glockshooter
willowbrook il
Ok a little help and advice
i want to do a mild build to my car i want to get a cam, heads, and intakes for my car i. Want to get a good set up and here is what i was thinking of doing i would appreciate any info and feed back on why or whynot i am going with a good setup
Ok i have a 94 gt convert 5 spd
Here is what i was thinking
I would like a nice mild cam i was thinking an e303 i want a good all around cam that will have good idle
i was thinking a nice set of aluminum heads like tfs, edelbrock some mild but gives a noticeable power increase
and holly systemax upper and Lower .with a 70 mm throttle body cai and either 19 or 24 # injectors
Also underdrive pullys headers and a offroad h or x pipe the car already has a mac cat back
i am going to daily drive the car so i still want to get decent gas mileage any feed back is greatly appreciated
ProKiller
PA
just get a TFS top end kit, 24#s, 75mm T/B and cal'ed maf.
ProKiller
PA
lets put it another way. my solution is one of the easiest ways to get to 300hp. you can piece together everything but there is no rule that says you'll hit that power number. afr heads are great but they are costly. ford cams are out-dated and should be used sparingly. systemax intake is the of the best ones out there but if your going to use a ford cam, it's going to waste.
