help with drivers side window
realbkg
i need help with my 04 convertable the drivers side window has 2 issues one when the door is closed it sticks out about half a inch to a inch from the car leaving a big gap. the other issue is it rolled down when i first bought it about 2 weeks ago now it wont roll down the switch seems to work you can hear the things inside making noise like they should but nothing happings any idea would be great
07GtS197
Fort Myers, Fl
Do you have any pictures? I saw a post on Facebook about this recently and a few members said it’s because the top is out of alignment. Years ago I had a 98 v6 that had the same problem. The way I’d fix it is by closing the door by the window.
The next time you try to roll the window down, give the door panel a few thumps with your fist. The window motors in this car are known to stick intermittently like that.
Do a youtube search on 95/sn95 mustangs window bushings and it will show a part that has been known to break and cause this problem of it not moving. Now the gap sounds like either it has fallen off the track, the part that attaches the window to the track has come off or something is loose inside. It is hard for any of us to put our finger on it but if you get your eyes on it and can't figure it out take as many pics as you can and then maybe we can point you in the right direction. You would have to take it apart to replace the bushings so you can give it an inspection then for the tracks.
Mikehonco69
