HID Kit..thoughts
gt96stang
94GtStAnG5o said:
Just move to jersey and don't give a shit about blinding other drivers, we all run bright ass f'ing headlamps where I live, gotta get back at all the rich assholes in their audibmwmercetc somehow. I'm looking to get the 10k's in the spring unless I find an 8k set that strikes me.
the higher up the kelvin scale you go, the less light output there is.
Mesarina
right, but higher kelvin's bulbs still have more output than standard bulbs..
Mesarina
1BAD96SVT said:
Mesarina,
How do you go about adjusting them..
use a rathet with a 4mm socket, you remove the radiator cover, and you'll find 1 bolt for each headlight, if you can't get them high enough, youll need to use a 12mm (not sure) to remove the corner lights, and when you remove them, looking at the front of each headlight youll find a bolt that moves with a philips screwdriver...
here is another pic i took today
:santa_grin:
gt96stang
oh yes, I most definitely agree, Just sounded like he was going for the blue because they were "brighter"
94gtstang50
I was going for the 10k b/c they are sexier, not brighter, although the brighter 8k ones would help with all the freakin deer around here.
gt96stang
Sweet!! Sounds good, when I get around to it, I will be going with the 6k probably, just to get a slight hint of blue but have the nice clear white while i drive..
1BAD96SVT
use a rathet with a 4mm socket, you remove the radiator cover, and you'll find 1 bolt for each headlight, if you can't get them high enough, youll need to use a 12mm (not sure) to remove the corner lights, and when you remove them, looking at the front of each headlight youll find a bolt that moves with a philips screwdriver...[/quote]
Looks awesome man just like mine there problem i am having though is mine aim high up i need to set them lower..
