Hids
97LSxGT
Wentworth, NC
bought a 35w HID kit for the headlights. ive read you need the relay harness and ive read you dont.
do i absolutely need it? the harness i bought came with no instructions(go figure) and doesnt look like any other ive seen on the internet lol.
want to get them in tomorrow and yes ive put in HIDS many times just never have used a relay harness so its a first
if you need a pic of the one i got and can aid me in it if i need it then ill put one up!
sometimes they flash if there is no relay used. Just like you said you did it with out them, well then you have your answer. I did it just because the headlight switch in our cars is known to go bad but with a relay it will be less likely to happen.
relays are not hard and I can get you through it if you want.
97LSxGT
97LSxGT
Wentworth, NC
ive never did one with a mustang just my fogs. never had one on any of my GM's. im trying to get a rough picture up for what im trying to figure out. watched a vid and kinda got it down but mine does not have the "signal" wire to turn the em on like the vid but im thinking its the plugs for the cars factory harness if you werent using the relay.
97LSxGT
97LSxGT
Wentworth, NC
i appreciate the help btw. the business i always buy mine from got bought out and there kits are totally different and last company gave ample instructions..these none..lol
they didn't include directions because its plug n play. Connect the red wire to the pos side of the battery, and then plug the drivers side stock headlight hrns into the matching hrns on the left side of your pic. It will only plug into one place and you can't get them backwards. Now the only remaining connection will go to the ballast, and then from the ballast to your HID light. Now run the wiring needed for the passnger side over and do the same with the ballast and hid light.
I have also heard of antilock braking errs popping up depending on where you put th ballast. I put mine behind the batter on the drivers side and under the intake on the pass side and never had a problem.
97LSxGT
97LSxGT
Wentworth, NC
okay pretty much what i figured then correct?
sorry to sound like a DA lol but wanting to make sure i get this junk right with no headache
and yeah i found that out when i did my fogs. im gonna relocate them tomorrow as well..thanks for the tip man
don't let it get you uptight, you really can't screw it up unless you plug into the high beam instead of the low and that just take a sec to fix.
97LSxGT
97LSxGT
Wentworth, NC
just a heads up i got em in. went in like the picture i put above. lol i appreciate the the help ttocs!
