Highlighted posts from Friday, Oct. 22, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
October 21, 2021 * 11 posts * 47 views
94StewFord said: I can't find any out there, any help would be appreciated. Looking to go with a catless H-pipe and Dynomax Super Turbo mufflers in 2 1/4" or 2 1/2" Also sticking with stock exhaust ... Read more >>
October 22, 2021 * 10 posts * 96 views
TrickVert said: For a $500 budget, I'd install subframe connectors and check and replace worn shocks and/or suspension bushings, and consider lowering Springs (no more than 1.5" drop). I'd change ... Read more >>
October 21, 2021 * 3 posts * 16 views
Jakespeeds said: I am thinking about taking my Roush Side exhaust off and going back to the original tailpipes out the back. Anyone have a set from the mid-pipe all the way out the back factory ... Read more >>
October 21, 2021 * 6 posts * 89 views
Duff said: Yesterday, I put on new pads, got rid of the caliper covers and installed the new lug nuts, drove for an hour and everything worked out well. I'm guessing the wheels are not replicas, ... Read more >>
October 22, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Parking brake getting loose? October 20, 2021 * 15 posts * 115 views General Tech How much am i pushing and how much more can i ... Read more >>
October 22, 2021 * 8 posts * 142 views
J_lope82 said: I was finally able to get under the car and inspect the driveshaft. I found a couple of things. First is the flange bolts were loose. I put a wrench on them and was able to spin ... Read more >>
October 21, 2021 * 10 posts * 115 views
Danfixxer said: Ok guys here is an update of the abs light situation. Like I said the abs light didn't come on at any time. The abs module didn't communicated any signal, so the light stayed off ... Read more >>
October 21, 2021 * 26 posts * 333 views
BOS-94-003 said: Just paid 176 for a duralast gold at autozone for my 17 explorer sport. Terminal was so corroded that it broke off trying to remove the clamp. Would of preferred a motor craft ... Read more >>
October 21, 2021 * 68 posts * 741 views
Chris Stephens said: Simplicity, ease of install, and price. It's about $1000 for the base Sniper, takes the place of nearly any carb, and has the ECU mounted directly in the throttle body, reducing ... Read more >>
October 21, 2021 * 24 posts * 334 views
BOS-94-003 said: I never would of guessed that cover was 126. Either I'm getting old or stuff is just expensive Read more >>
Continue reading...
senior001
Staff online
