Highlighted posts from Monday, Apr. 19, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
April 18, 2021 * 10 posts * 138 views
Jakespeeds said: Well 98 does not have a distributor. It uses a crank trigger. There is a little more to the system than that. But check the plug on the crank trigger. If that visually looks OK ... Read more >>
April 18, 2021 * 6 posts * 197 views
Wmac said: When you say Cobra axle, are you referring to a 31 spline diff? FRPP gear set ........... 200 bucks or so. FRPP gear install kit .. 100 bucks or so. (has all the bearings needed) ... Read more >>
April 18, 2021 * 8 posts * 184 views
lwarrior1016 said: @Burninrock24 i don't know if you'll find one for a reasonable price. I've been looking for the same thing. You might end up having to get someone to build you a custom setup. Read more >>
April 19, 2021 * 1 post * 11 views
SN95Newsletter said: Click here to view on the web Highlighted posts 3 inch seamless/tipless IRS catback April 17, 2021 * 6 posts * 125 views Exhausts Well, there goes a wad of money... April 17, 2021 ... Read more >>
April 18, 2021 * 3 posts * 114 views
skidoo said: What's the offset on your rear wheels? I have a set of weld superlites that I used to run on my 73 mach 1, 15x10 with 6½ back space. Nice car, what's in it? Sent from my Pixel ... Read more >>
April 19, 2021 * 5 posts * 129 views
Wmac said: Update: Welded bungs on each side, in very close proximity to the 02 bungs. Bought an AEM 300 x series wide band, seems to work ok. First big test will be whenever the track opens. ... Read more >>
April 18, 2021 * 26 posts * 454 views
lwarrior1016 said: You're being held back by the tune. When the tuner set it up, they made it adjustable with the handheld but only let you adjust up so far. Don't get too crazy with timing though, ... Read more >>
Continue reading...
