Highlighted posts from Monday, Aug. 30, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
August 29, 2021 * 22 posts * 111 views
ttocs said: I just had to fill my t56 and I remembered that I had a hand operated small fluid transfer pump I got a while back from harbor freight that made it easy to just stick the hose ... Read more >>
August 29, 2021 * 7 posts * 25 views
Makoto said: Hey guys so of course AFTER i order and install the 23 tooth speedo gear for my T45 that has 4.10 gears I find out they'll apparently be wrecked after a few feet of driving. Funny ... Read more >>
August 29, 2021 * 23 posts * 250 views
J_lope82 said: It hasn't done it any more I'll keep an eye on it though. I guess it heard us talking. Read more >>
August 29, 2021 * 5 posts * 20 views
PinkieT said: Whoever installed the exhaust on my wife's 98 GT must have never passed a welding class or owned a level... I have the old factory six cat h-pipe, flowmaster clones a PO had booger-welded ... Read more >>
August 30, 2021 * 4 posts * 29 views
ttocs said: This would be the first time I have heard of someone paying a shop to do it. I thought the only advantage was that you could do it yourself, it cost no $$$ so the bad ride(that ... Read more >>
August 29, 2021 * 1 post * 14 views
delling3 said: In the midst of a PI cam and intake swap. I have finally made enough progress to begin reassembly. I've had a roadblock or two along the way, but I started putting stuff back together ... Read more >>
August 30, 2021 * 1 post * 12 views
Monday said: I have had the rear end of my 96 GT Vert apart for the last three weeks. I have rubberized and undercoated the last half of the car, and it's pretty much back together - BUT - ... Read more >>
August 30, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Does this belt need replacing? August 28, 2021 * 74 posts * 445 views 94-95 5.0 - Specific shifter goes into gear but no movement ... Read more >>
August 29, 2021 * 6 posts * 87 views
Mr. Blue said: I had a similar problem on my 95 GT. As mentioned above, i also went to Ford to inquire about a replacement air bag control module which is mounted under the dash. They told me ... Read more >>
August 29, 2021 * 6 posts * 100 views
GS_Geoff said: Never got it running right. Starter was replaced, clutch safety switch was replaced, battery is known good, ignition was replaced and the starter is getting power. Still no idea ... Read more >>
Continue reading...
jhonswilliam80
