Highlighted posts from Monday, Feb. 14, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 13, 2022 * 17 posts * 92 views
ttocs said: the set I got all I had to do was pound them out with a hammer and then I used special bearing that I put on it and then used the impact wrench to pull it into the hole. Even with ... Read more >>
February 13, 2022 * 22 posts * 227 views
RAU03MACH said: I know one of them is roots only You really don't hear mine until your foot is in it If I'm in the car I hear nothing but flowmasters Read more >>
February 13, 2022 * 30 posts * 257 views
Daryl said: I noticed a little inconsistency on fitment between each side. One side lined up with the fender. The other was off about 1/2" +/- [image] passenger side just a tad off vs drivers ... Read more >>
February 13, 2022 * 6 posts * 56 views
Booboo said: That was it, the hose was disconnected from the valve cover and pushed out of the way. Read more >>
February 13, 2022 * 2 posts * 27 views
Pallgor said: I've been having a coolant smell in my 96 4.6 gt. I did a pressure test and only found a leaky hose clamp which I fixed. Tester held pressure after I retested it. I still smell ... Read more >>
February 14, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Turbo or Supercharger? February 12, 2022 * 20 posts * 159 views 96-04 - 2V Specific 96 cobra fuel tank February 12, 2022 * 15 posts ... Read more >>
February 13, 2022 * 131 posts * 1,277 views
Pedrothecobra said: No I think I have a bad oil ring on one or 2 cylinders. It's burning oil pretty good, didn't notice it till yesterday when I was jumping on it Read more >>
Continue reading...
