Highlighted posts from Monday, Jun. 28, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
June 24, 2021 * 8 posts * 66 views
tinnocker said: First, it is not going to be stock. I already have a ported GT40 intake and the 45 degree adapter made by Edelbrock, that I haven't installed it yet and do not know if the stock ... Read more >>
June 25, 2021 * 6 posts * 31 views
ttocs said: you checked one fuse? IF that is the case go back out and check all the fuses. I know it sounds like a PIA but it honestly only takes 2 mins to pull and inspect them all. Its really ... Read more >>
June 25, 2021 * 4 posts * 39 views
dookiemane said: I never thought of the fuel float, I guess that would explain how it's been slowly working less and less. Dropping the tank is a PITA but since it's the weekend I'll try and check ... Read more >>
June 28, 2021 * 13 posts * 168 views
Adfalenski said: I just took a look at Amazon for electric power steerig. Here is the link: [link] . It is amazing what is available. Read more >>
June 28, 2021 * 2 posts * 11 views
96blak54 said: Well.....by the tag its has a 2:73 limited slip rear. They were common from 94 to 96...iirc. 3:27 became the normal their after. Im not saying this info is set in stone either. ... Read more >>
June 26, 2021 * 5 posts * 63 views
96blak54 said: Its more of a hobby right now. It may lead into making a profit later. Im still learning the modular valve train even tho i feel like i have a good grasp on it. Also learning the ... Read more >>
June 26, 2021 * 1 post * 19 views
David said: Hey everyone. I'm having a little bit of trouble finding information on this particular issue. I purchased a car from an area where emissions inspections were not required. It ... Read more >>
June 28, 2021 * 1 post * 7 views
Oxentine said: What's up folks, got a 01 v6 that's getting turned Baja and I've been pondering on suspension. Run a coil over lift or just find another fomoco product that uses the same perches ... Read more >>
June 27, 2021 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts What CAI fits? June 24, 2021 * 8 posts * 39 views 94-95 5.0 - Specific Power steering options? June 22, 2021 * 12 posts * 142 views ... Read more >>
June 28, 2021 * 18 posts * 212 views
RAU03MACH said: When oil is at the top in the valve covers The baffled part in the valve covers oil gets past that And a supercharger will pull more oil at the top end I'm not really sure why ... Read more >>
Continue reading...
