Highlighted posts from Monday, Nov. 01, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 01, 2021 * 8 posts * 38 views
Buffalo5Spd said: Hi Bronco, since I just had the same problems with my 95 GT I'll throw my $.02 in here. I've replaced 3 of the 4 window motors. First off, I knew from the previous owner that the ... Read more >>
October 31, 2021 * 7 posts * 73 views
Makoto said: You should be able to run the turbo and just keep it from making any boost by making the wastegate stay open. turbo systems work off pressure equalization. just use that. Read more >>
November 01, 2021 * 3 posts * 46 views
Wmac said: If you have a 4r70w trans, it would have to be from a 3.8 because of the different bolt up pattern. (4.6 has a different pattern from the 3.8 & 5.0) All 4r trans pans have a sump ... Read more >>
October 31, 2021 * 1 post * 18 views
joshwellfleetcapecod said: Background first and questions at end. Tried researching . Just got a screaming yellow 04 GT convertible manual, 95K miles mint shape. summer only northern vermont car. has Pypes ... Read more >>
November 01, 2021 * 1 post * 5 views
SN95Newsletter said: Click here to view on the web Highlighted posts 1995 mustang 4v swap October 30, 2021 * 28 posts * 315 views 96-04 - 4V Specific RGB Halos October 30, 2021 * 4 posts * 23 views ... Read more >>
Continue reading...
hazel113
