Highlighted posts from Saturday, Dec. 18, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
December 18, 2021 * 18 posts * 69 views
07GtS197 said: It depends on what's going on. If it's actually not going into overdrive I'd put money on the mlps not working right. I wonder if the previous owner removed the button and wired ... Read more >>
December 17, 2021 * 19 posts * 88 views
Chip66 said: What is the voltage at the starter and at the battery when the starter is engaged? If you are seeing voltage anywhere go below 10.5 volts there is not enough amperage available. ... Read more >>
December 17, 2021 * 12 posts * 77 views
joemomma said: Joe works :) I may attempt that over the winter, just depends on how much free time I have and how long the car is in the body shop. All my stuff is in storage at the moment, but ... Read more >>
December 18, 2021 * 8 posts * 42 views
Gregomatic said: Mine turned out to be a tie rod end bushing. Get underneath and start by lubing the most suspect part. I would say just grab some blaster and hit everything that moves, but then ... Read more >>
December 17, 2021 * 5 posts * 30 views
joemomma said: If it's going to be covered with the carpet overlay, I'd probably use plexiglass or some kind of ABS plastic. It will be stronger and lighter than 1/4" plywood. 1/4" plywood has ... Read more >>
December 17, 2021 * 57 posts * 445 views
Notthenow said: Access hatches are great. The SN95 tank is easily to drop compared to 4th gen Camaro, but a hatch makes it great. The s197 has two hatches stock, one for each side of the saddle ... Read more >>
December 18, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts 94 GT starter engages but won't spin motor. December 16, 2021 * 9 posts * 33 views 94-95 5.0 - Specific What rpm do you idle at? ... Read more >>
December 17, 2021 * 45 posts * 406 views
ttocs said: you gotta do what makes you happy. Now stick a cobra emblem on it though and we cannot keep the cobra dudes back... Read more >>
December 17, 2021 * 46 posts * 1,469 views
95opal said: My old AFR165, holley and fti cam made 325. Im pretty sure you will achieve your goal Read more >>
Continue reading...
Suprasuavy
