Highlighted posts from Thursday, Jun. 10, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
June 09, 2021 * 14 posts * 175 views
skidoo said: Check compression on all 8 cylinders? Did you double check the firing order? Standard 302 and HO use a different firing order. You can briefly touch each header tube as it's warming ... Read more >>
June 09, 2021 * 4 posts * 42 views
Daryl said: I did a search on the Forum and came up with a thread from 2017. Anticipated advice therein, but that was 4 years ago. So, thought I'd ask again in case there's any further information ... Read more >>
June 10, 2021 * 4 posts * 80 views
RAU03MACH said: How was it after leaving the shop that worked on it And how many miles were you able to put on it when it was done When you are tapping the brakes your slowing it down of course ... Read more >>
June 09, 2021 * 2 posts * 112 views
trebor3170 said: Yes, it is worth it. See here, [link] , how to calibrate your speedo and tach, then decide if it's something you feel comfortable doing. As far as the other gauges, just bring ... Read more >>
June 09, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts Engine vibrating 3K+ rpm. June 09, 2021 * 11 posts * 115 views 94-95 5.0 - Specific Spark plug diagnostics June 08, 2021 * 25 posts ... Read more >>
June 09, 2021 * 12 posts * 298 views
weendoggy said: Actually, you should be using a noid light to test injector harness, not a test light to see if it's firing. You can do damage to the electronics. Injectors can be a toss up on ... Read more >>
Continue reading...
