Highlighted posts from Thursday, May. 06, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
May 06, 2021 * 15 posts * 308 views
Flade said: Well I got lucky and the flywheel was fine and Th e machine shop had no trouble turning it. Read more >>
May 05, 2021 * 3 posts * 54 views
BlackStallion said: Been a while since I've been here, but I'm finally about to start converting my 94 GT to Cobra brakes (all 4 corners), I've lurked around the internet and discovered that I appear ... Read more >>
May 05, 2021 * 3 posts * 48 views
Venompower said: SO I have recently discovered that the AEM 30-4100 Wideband AFR gauge in my Cobra has no 02 Sensor... it reads a static 14.7/14.8. One of the many interesting things I have found ... Read more >>
May 05, 2021 * 3 posts * 50 views
Steve Downs said: Hi all! Can anyone tell me if the rear axle on a 1996 Cobra SN95 is the same as a Gt V8? We are repairing one that was crashed and spun hitting the rear wheel damaging the axle ... Read more >>
May 06, 2021 * 1 post * 22 views
90foe_5.0 said: After putting this on the shelf for months I finally have the gt40 upper and lower and heads. Now .. I'm going to be keeping by stock H.O cam im only changing heads and up nothing ... Read more >>
May 05, 2021 * 1 post * 18 views
Adam Vinnicombe said: Hi all has anyone over in the states heard of SSI Performance? If so are they any good? They are saying that they can give me two tunes for $170. There isn't anybody in the U.K. ... Read more >>
May 06, 2021 * 1 post * 15 views
SN95Newsletter said: Click here to view on the web Highlighted posts New 98 gt project May 04, 2021 * 9 posts * 102 views 96-04 - 2V Specific Cam Girdle cracked May 05, 2021 * 7 posts * 74 views 96-04 ... Read more >>
May 05, 2021 * 26 posts * 485 views
Adam Vinnicombe said: Just to let you all know after moving the exhaust further away from the prop shaft the grinding noise has stopped :) Read more >>
May 06, 2021 * 11 posts * 211 views
dcm0123 said: We are running a Derale fan similar to this. Is only 3" thick with the shroud. The fan size is 17", high flow and is available in different shroud sizes. I do not remember the ... Read more >>
Continue reading...
