SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
August 23, 2021 * 9 posts * 49 views
TrickVert said: Is your car lowered? If so, check to see if the parking brake cable bracket is rubbing on the drive shaft. Read more >>
August 24, 2021 * 6 posts * 16 views
J_lope82 said: I noticed my Speedo is starting to act wacky. On take off it stalls at around 10 then all of a sudden jumps to around 25mph. Any one experienced anything like this? Is my Speedo ... Read more >>
August 24, 2021 * 5 posts * 20 views
VEE8FBODY said: Looking for advice on a turbo set up for my car ? any suggestions and advice welcome thanks [image] Read more >>
August 23, 2021 * 6 posts * 68 views
white95 said: You can adjust the pre-load on the steering rack. [image] Read more >>
August 24, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Highbeams fog light issue August 23, 2021 * 14 posts * 65 views Electrical & Stereo Screeching Sound When Reversing August 22, 2021 ... Read more >>
August 24, 2021 * 1 post * 12 views
IBsenoj said: Hi y'all. I'm new here, thank you in advance for reading this long post. I have a POS 1994 V6 (sad) Mustang I bought for $300. I'm starting to think restoring it isn't a good idea. ... Read more >>
August 24, 2021 * 2 posts * 49 views
white95 said: Sorry this was missed but I believe it's 110 lph. Read more >>
August 24, 2021 * 3 posts * 64 views
RAU03MACH said: If the chain was that far stretched that its hitting the cover Than that is what they would be talking about As long as every thing on the inside of the cover looks good No cracks ... Read more >>
August 24, 2021 * 42 posts * 464 views
Venompower said: VMP suggested replacing the harness as a starting point. They advised you could see in the data log where the MAF data was intermittent which indicates a short. I still think the ... Read more >>
Continue reading...
