Highlighted posts from Tuesday, Feb. 01, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
January 31, 2022 * 19 posts * 159 views
Procharged87 said: I used a T56 from an 03-04 Cobra to replace my T5. Has a higher first gear (2.95 vs 3.35) which makes first more usable and a higher 6th gear for highway cruising. Problem for ... Read more >>
January 31, 2022 * 11 posts * 118 views
Notthenow said: Check the evap solenoid, they can be flaky. It sits on the passenger side strut structure under the a/c dryer. Maybe it bouncing off the structure finished it off or affected the ... Read more >>
February 01, 2022 * 5 posts * 21 views
Pallgor said: I've narrowed it down to be coming from the cowl and leaking into my driver's floor. Is this a common problem? I still want to do a light test but I'm wondering if Anyone else ... Read more >>
January 31, 2022 * 5 posts * 64 views
lwarrior1016 said: Most of the wiring. The ecu pin out is different, the fuel system wiring is different, and I think the gauge cluster wiring is different. Read more >>
January 31, 2022 * 1 post * 11 views
SN95Newsletter said: Click here to view on the web Highlighted posts 5-speed to 6-speed tranny? January 30, 2022 * 13 posts * 87 views 94-95 5.0 - Specific Pothole leads to misfire... January 30, 2022 ... Read more >>
February 01, 2022 * 1 post * 9 views
1998MustangVert said: I have a 98 mustang with PATS II. I currently have three keys, one original Ford key, and two aftermarket keys from locksmiths. All of them have had a fair bit of abuse in the ... Read more >>
February 01, 2022 * 12 posts * 239 views
1998MustangVert said: Sorry to push into this forum, but I just ordered a few new keys to replace mine. After 23 years they are pretty beat up, one is cracked at the loop it can't be used on a key ring ... Read more >>
Continue reading...
