SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
February 01, 2022 * 11 posts * 75 views
ttocs said: The only holes I can think of on the pass side are in the firewall for the heat/ac up high and then the place the water drains from the ac at the floor. Check the seal around the ... Read more >>
February 02, 2022 * 14 posts * 179 views
ttocs said: It can be very hard to see if a harness has a bad connection seriously start the car and just go dick with all the wire harnesses you can see. Don't be afraid to get a little rough ... Read more >>
February 01, 2022 * 13 posts * 191 views
ttocs said: I would not use cheap sound damping in that location by any means and you would need to prep the area really well. Read more >>
February 01, 2022 * 102 posts * 877 views
Adultingsucks said: Just a follow-up. Pulled an amp reading of the fuel pump feed at idle. Current draw is 6.4a @ idle. Won't be able to do a WOT amp measure until the snow clears. Read more >>
February 01, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts 5-speed to 6-speed tranny? January 31, 2022 * 19 posts * 159 views 94-95 5.0 - Specific Pothole leads to misfire... January 31, ... Read more >>
February 01, 2022 * 16 posts * 266 views
1998MustangVert said: I assume using forscan? I really don't want to remove any keys because if they work they'll be good to have as a spare if something happens. I also don't want to get into using ... Read more >>
Continue reading...
