Highlighted posts from Tuesday, Jul. 13, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
July 12, 2021 * 17 posts * 124 views
joemomma said: I' had a Hurst Billet Competition on my '06. It was fine, but it would grind 2nd on a really aggressive shift sometimes. I had a Pro 5.0 in my '99, which I loved. It was fairly ... Read more >>
July 13, 2021 * 9 posts * 50 views
delling3 said: What side of the engine are you guys able to access the bolts from? I got the upper bolt out from the left side, but cant even get close to reaching the lower bolt head. I can ... Read more >>
July 13, 2021 * 3 posts * 7 views
96blak54 said: Here i am again with my bright ideas!! Honestly i think my mind has become my nemesis. I start these projects with hopes of finishing them in a reasonable time frame, knowing i ... Read more >>
July 12, 2021 * 1 post * 14 views
Notthenow said: I am degreeing in Comp 262AH cams in pi heads on an 1998 NPI. What clearance spec should I shoot for on the intake valve? I have seen .035 mentioned, but not sure if that is a ... Read more >>
July 12, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Help with swapping the coolant tube: PI Intake Swap July 11, 2021 * 6 posts * 23 views 96-04 - 2V Specific Comparing shifters July ... Read more >>
Continue reading...
