Highlighted posts from Wednesday, Apr. 13, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
April 12, 2022 * 18 posts * 208 views
95opal said: The cobra mirror has a small portion that hugs the square bodied new edge at the bottom of the mirror. It needs to be trimmed off and reworked to the sn body line. Simple mod that ... Read more >>
April 12, 2022 * 19 posts * 147 views
Randall Garner said: Check you cable from battery to fuse block in engine compartment. It may of failed Read more >>
April 12, 2022 * 17 posts * 230 views
Makoto said: i love my bc racing coilovers but I have a 99 cobra IRS so the rears would be a tiny bit different (IRS springs are bigger in the back). the valving actually changes the firmness ... Read more >>
April 13, 2022 * 5 posts * 16 views
d.garza18 said: So I've recently purchased a 2000 v6 new edge. Got it for next to nothing knowing it needed trans work. Removed old transmission, the torque converter was locked in the transmission. ... Read more >>
April 12, 2022 * 8 posts * 92 views
Evan Wood said: Thank yall for the info, that helps a lot. 5.0 it is. Read more >>
April 12, 2022 * 14 posts * 149 views
Daryl said: RESULT!!! All 3 (speedometer, odometer and cruise control) now work! A few things were involved on initial inspection and code reading, but the primary fault was a pinched wire ... Read more >>
April 12, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Throttle bodies April 11, 2022 * 24 posts * 169 views 96-04 - 2V Specific Weak rear brakes April 11, 2022 * 9 posts * 40 views Suspension ... Read more >>
April 12, 2022 * 42 posts * 550 views
Randall Garner said: You can get aluminum heads for about the same price look at that option also Read more >>
Continue reading...
Suprasuavy
