Highlighted posts from Wednesday, Jan. 26, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
January 25, 2022 * 48 posts * 337 views
ttocs said: there are normally 5 pins on the relay. pins 85/86 go to the coil and when energized make it click. The other three pins go to the switch contacts and two of them are common when ... Read more >>
January 25, 2022 * 13 posts * 96 views
ttocs said: again unless you are up to the point of replacing the heads/cam your just wasting money. Yes you can mail it back and have him reburn it but realize you will need to reinstall ... Read more >>
January 26, 2022 * 11 posts * 84 views
Coondawgnewedge said: I'll have to look into one thanks for the info! Read more >>
January 25, 2022 * 4 posts * 31 views
That Mustang Guy said: I have one and all 6 disc slots work. It's still in the car and works perfectly, Hasn't been pulled out, and just sitting in storage. Read more >>
January 25, 2022 * 3 posts * 11 views
joemomma said: Painter said it would be good if we could find a new hood insulation pad. With the hood being aftermarket/fiberglass and unknown brand, all the kits I'm seeing are for stock hoods ... Read more >>
January 25, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts 96 cobra breaks up under WOT January 24, 2022 * 41 posts * 269 views General Tech Thinking of selling my 95 GT January 25, 2022 ... Read more >>
January 26, 2022 * 5 posts * 84 views
Daryl said: Mission accomplished! Only replaced the horizontal motor. Sending vertical back but, The vertical was fine. Seat works like new! Lovin'it..... Next..... use that new leather conditioner ... Read more >>
January 26, 2022 * 32 posts * 419 views
dcm0123 said: An EGR valve malfunction would not cause a rich running engine. Pull the vacuum line off the fuel pressure control valve to make sure it is not full of fuel. This would be signs ... Read more >>
January 25, 2022 * 9 posts * 279 views
That Mustang Guy said: I have an engine harness in a tote I'll locate it today and let u know. Read more >>
January 25, 2022 * 5 posts * 134 views
That Mustang Guy said: I have a couple of them, I'll send you some pics of what I have. Read more >>
Continue reading...
lndabrkes01
