How do I buy the proper intercooler?
MustangChris
Aurora, CO
Hello all,
Im starting to keep my eyes peeled for parts for my build, now that I'm starting finally. lol.
How do I purchase a proper intercooler? (this might be a good sticky thread.)
I'm NEVER going to run under 17 PSI and NEVER over 26 on a top mount.
The salesman at Kenne Bell said to use an OEM 2003/2004 cobra one. After I asked him if this would be a "restriction," he said the following:
"Yes you can run the stock lower and stock I/C at any boost the compressor can produce. Is it a restriction? Possibly, but I don't know of anyone who makes an intercooler core for those vehicles. You can get a larger heat exchanger for the front of the car but the core is probably as good as it gets unless you make your own core. " - TJ Sico ~ Kenne Bell Tech Support ~ 8-19-2009.
I understand that intercoolers come in a variety of shapes, sizes, and depths. How do I know which one is right for me?
Do they come in different matierials? are some materials better than others? will painting it or powder coating harm performance?
What are my options?
Thanks all,
Chris
blown98gt
first off there are different types a/a a/l so you have to decide on that. the procharger 3 core a/a is a great intercooler imho and i've had great success with it at 20lb of boost on a daily driven car.
you are defiantly going to want at least a 2/3 core i'd say go 3 core and as far as a/l is probably the best route for you also. the only reason i've not had any issues with a/a is because i'm also running meth injection. if you are running a kb you might want to look into like 03 cobra i/c upgrades because most of them are good upgrades for the kb
MustangChris
MustangChris
Aurora, CO
Okay. What are the benefits to a/l vs. a/a?
Is the OEM Cobra a 3 core? or 2 core? Is it a/l or a/a?
Daily driven I will probably be running 18 PSI. and 25 at the track. (yes i realize this will take a pulley and belt swap at the track)
Thanks for your help :)
Also, will powder coating or painting it cause performance issues? or are there certain materials that work better than others, (aluminum instead of steal?)
blown98gt
if i were you i'd defiantly look into getting a meth injection for boosting that high, also aluminum is always cooler from what i've seen than steal. powder coating it shouldn't cause any performance issues but i've not done it. nor have i seen or met anyone who has done that. i believe the OEM cobra is a 1-2 core. I didn't even know the KB would see 25psi even on their mammoth kit. You will "HAVE" to run an 8 rib setup. there is no question to it, there is no way you'll hit 25psi on a 6 rib and there is no way you can hit 25psi with no belt slippage. So go ahead and plan on swapping over to an 8 rib pulley setup. You'll gain a few psi on the swap alone but doing it on the d1sc was the best thing i've done 0 belt slippage at 20-22lbs of boost.
Look into a RR 8 Rib pulley because they make 8 rib pulleys for KB, prochargers, and so on. also look into a BGG 8 rib kit.
i know i was pretty vague and didn't answer all your questions but a/a is just air going through the intercooler (small layers of stuff that cools the air lol) and a/l exactly how it sounds, air is cooled with liquid when it passes through the intercooler
blown98gt
he's running a kb not a paxton, vortech or procharger... kb is different in the twin screw vs centri. if it was me the procharger 3 core fits great has been on 1000 hp applications and is a great intercooler.
MustangChris
MustangChris
Aurora, CO
i think ill get an aluminum, a/l, 3 core, black intercooler.
as for the 8 rib belt, already budgeted that into the build :) gunna be on my list.
the KB 2.8 mamouth is so far the only top mount for the 03 that runs to 26 PSI. (according to kenne bell) the salesman said they were working with a whipple and it blew up at 26, so thats where they stopped testing the KB. lol. i plan to run 25 MAX, 18,000 RPMs MAX, and 17 PSI min.
Thanks for your help all! :) feel free to add any additional information incase this thread gets a sticky note.
MustangChris
MustangChris
Aurora, CO
justinschmidt1 said:
Uh, do you have a 03 cobra that I dont know about?
lol, no. I have a Teskid 4 bolt aluminum block thats getting 03 cobra heads and 2.8 KB. :) (check out my build thread :-D lol)
will there be problems fitting an 03 intercooler in the front opposed to an aftermarket one?
330CubeGt
Im running stock boost right 8-10 psi now :dontknow: but i have a 03/04 cobra Heat Extractor and a Moroso Supercharger tank/ Ice box.
The Lightning unit is almost identical but is taller and i wish i had known when i bought this one because stock for stock the lightning one is much better.
If you can get a Dual Pass extractor,That way the water has more time to cool.
the Moroso tank i run is about the size of a battery but i have been thinking of a 2-3 Gal tank in the trunk to stuff with ice so thats always a option for you.
Here is a link for a 03-04 LFP Extreme Dual Pass Intercooler
http://www.lightningforceperformance.com/index.php?main_page=product_info&cPath=234_129&products_id=319
MustangChris
MustangChris
Aurora, CO
thanks 330. if i end up getting FOMOCO parts, ill go with the lightning instead of the cobra. thanks for the hook up.
