Austinx56
how do i check my drive gear, i'm re calibrating my speedo i found my gear ratio now i need to check what gear drive i have .....
94 auto is not a t45... What gear do you have?
Ill give you what you need in one sec
but your tranny is an 8 tooth drive gear.. Again what speedo and drive gear you need is all dependant on what gears are in the rear of the car
looks like he wants to calibrate the new cluster to his car.
im not sure if changing the speedo gear will work....
you may have to get the ecu or pcm reflashed to the cluster....
yeah it says im doing 60 but im doing 45You should just buy a gear depending on the rear ratio. BUT, since you have not changed it, it should be OK. The gear is in the tranny not the cluster. However, I don't know anything about the 200mph speedo, do you know how much off it is? You can get a GPS app for your phone to find out for sure.
