How many qts. Mercon needed
Tomwas
Having my filter and pan gasket replaced, how many quarts are needed to refill after the job... 98 4.6 gt automatic...
It’ll be roughly 6 quarts. Depends on how long it’s been sitting still and how long you drain. I would pick up 8 to be safe. Don’t forget that it takes Mercon V. Don’t use dex/merc, that will lead to problems.
Addicted
Kentucky
Are you draining the torque converter at all? IMO I would go ahead and do it while your there. It's around 14 quarts if you drain it all.
Tomwas
Tomwas
Not going for the converter.. The pan gasket is just leaking.. Not having a problem thank god...
Tomwas
Tomwas
Having second thoughts now, when doing my brake job I found lots of old ps fluid up in the driver side fender well below that power steering booster jobby.. Thinking this is leaking in some manner and going below the car on to the cat... Wiped it down under the Car today finished see the source.. But it's also got old fluid below the unit on the firewall also... Is this known for leaking at all..??
Addicted
Kentucky
You need a new hydroboost assembly, I would get it fixed asap. It can cause other issues.
Tomwas
Tomwas
I'm 68 and a shade tree mechanic, don't think I would attempt it myself though..
Tomwas
Tomwas
What other issues would it present.. Just wondering..
Addicted
Kentucky
I want to say it would cause issues with your brakes and steering. Your power steering is what runs it all. I'm kinda surprised your not have any power steering whine, possible brake fade. How long has this been this way? Forgive me if youve stated this already.
Addicted
Kentucky
Put it this way, if you take your serpentine belt off, your power steering goes, along with your brakes. Our specific design is a step up from the fox body units. Many do the swap on there car, thats why a junk car is not always junk.
Tomwas
Tomwas
Only had it two weeks. Noticed that the ps resovoir was filled up, cap says, do not overfill... I sucked some out of it to level it off where it should be. PO had it five years and his daughter drove it during college...
Addicted
Kentucky
Yeah bro if it was a college car, it got drove around alot, I'm paying for that now with my car, its tore apart. Youve got a nice car, just TLC. I would get it fix though asap. If you can wrap it somehow with rags where its leaking at, that would help with it running down into everything. Most of our liquids are hazardous to the exterior or interior of whatever it touches. I don't want to see something happen that can be prevented, especially when it involves your safety parts like steering, and braking!
Tomwas
Tomwas
She put 30k miles on it in five years... Car was in Jersey, she went to rutgers... The fluids actually preserved everything.. Paints like new in the fender well and under the hood once I wiped it down... I t Just get drips under it when it's parked overnite...
Addicted
Kentucky
Definitely monitor it. Be safe brother.
