My engine is a rebuilt 302 with a Vortech, the only oil I added was about 1/2 a quart in the lifter valley to lube the lifters. How many quarts should I put in? I was thinking 6.5 or 7 quarts?
Stock pan? find out how much the vortech takes (assuming it's fed from the motor) and add that to 5qts. Then top it off after you run it, if necessary.
