How to get the door to shut like new?
caseypayne69
My GT has over 240,000 miles on it. When I hope and close the door it feels like an old clunker with no precision in door design like todays cars. That quietly shut and shut firm and right you know what I mean. What can I do to get my car to shut well, like a newer car? Closing the door just shows my cars age compared to all this new car quality going around. My buddies 2002 SS doors feel just right. Makes my car feel like trash.
d232
Sounds like you need to replace the hinges, or do the hinge pin fix. I need do do my drivers door also. It drops down slightly when you open the door. Anyone on here done it that can help us out?
Downshift
What year is your car? Mine shuts really nice. I just spray it with WD40 every once in a while and I can barely pull or push and it shuts with ease. I know what you mean though, my old car shut like a POS.
Fets
My door sounds like it weighs 2000lbs when it closes. It opens and shuts nice though.
Knuckles281
weather stripping doesn't really play that much of a part, unless your doors are leaking or something. The reason that your friends car doors shut nicer (along with a lot of new cars today), is that there is insulation in the doors that keeps everything from rattling around, so you get no sound but a solid THUD when you shut the door. Our cars do not have this. All the equipment is just hanging within the door, so you can hear it move when the door is shut.
As far hinge sagging, the best thing to do is to just replace them. If you can find a set of good ones from a junkyard and spraypaint them, that's much cheaper that taking it to the dealership (or, the stealership as I call it :p) The door hinges aren't really noticed anyway by most people, so nobody will ever know you did it probably. There are ways to fix the pin that I've heard of people doing, but I'm not sure on them or how reliable they are, so I'll let somebody else comment on that.
Jrgunn5150
Subframe connectors, and don't open the doors while it's jacked up if you don't have them.
Foster98GT
My Drivers side does this...
97GT4.6
Colorado
Both my doors kind of sag as well. Which caused the cheap aftermarket paint job to peel off the bottom, which has now started to peel off of the bottom of my drivers side door.
voidfinger
so if the reason it sounds so bad is that there is no insulation... would a sound deadening material like dynomat correct this? I've been thinking about this b/c my convertable is one giant rattle... even with subframes...
Ciotti
I replaced my driver side door hinges a few months ago and the difference was night and day. The door shuts perfect now but it did cost me dam near $400 in labor because the fender had to come off to get the hinges on and off, the new ones had to be painted, and everything had to be adjusted. Everything is perfect now though, big difference as my driver side door was sagging pretty bad.
C
caseypayne69
Note to self.
Replace hinges when ready to take off fender to be painted.
Stangbangin
a quick fix for this problem is to open the door and grab the bottom edge closest to you and yank it up as hard as you can a few times. Then try to close it. Do this a few times. In the body shop my dad uses a special tool that attaches to the posts and then you close your door on it and it does this same thing.
