When I purchased the car it already had aluminum heads installed. I was told they were Trick flow, how can I confirm this? The reason I ask, is my lower intake is leaking oil and is needing to be resealed, I am just trying to figure out what to torque the lower intake to?
Trickflow will be on the ends of the heads unless they are older ones. Also on the exhaust port side should be a part number.
I assume in the valley from the front and rear. 1994 5.0 forged internals, 12:1 Pistons, x303 cam, edelbrock upper and lower intake, trickflow heads, 70mm throttle body, 1.6 rockers, msd ignition, 24lb injectors, underdrive pulleys, bassani exhaust, 4.10 gears, 5 speed
Ok I knew I couldn't see any name on the rear but I could see some numbers 1994 5.0 forged internals, 12:1 Pistons, x303 cam, edelbrock upper and lower intake, trickflow heads, 70mm throttle body, 1.6 rockers, msd ignition, 24lb injectors, underdrive pulleys, bassani exhaust, 4.10 gears, 5 speed
