How to tell what cam is in my car.
955.0
baton rouge
I picked up a 95 gt from a guy off craigslist. Now ik it has a cam in it just don't know what it is..
evilcw311
Most Evil Member!
Louisville, KY
Unfortunately you’d have to tear it down to find out.
All you have to do is ask it what type of cam it is.
but as logan said you will have to tear it down to find out its answer. I am also willing to bet if you posted a video of the sound on facebook you could get 10,000 opinions on what it is.
baton rouge
plans for it? honestly i don't know right now. Head gaskets took a dump on me and i can't get the lower intake off. All 12 bolts are removed and its still stuck..
evilcw311
Most Evil Member!
Louisville, KY
Use a flat pry bar and work it back and forth carefully and it will pop loose.
evilcw311
Most Evil Member!
Louisville, KY
Still won’t budge I almost snapped a tire iron trying to pry it out
Uuuuhhhhh..........say what?!?!?
Have you tried a big rubber mallet and hitting all around??
evilcw311
Most Evil Member!
Louisville, KY
I’ve never tried using a torch to break an intake loose but I’m almost curious if it would help. I’ve never seen one so stuck that you’d bend a tire iron.
baton rouge
Tempting the only thing attached to the intake is the tstat housing.. do I absolutely need to pull the distributor
evilcw311
Most Evil Member!
Louisville, KY
Yeah get it out of the way. Even though it doesn’t go directly through the intake it’s hard to do it without damaging it.
baton rouge
They used permatex on the lower intake.... I’m fresh outta ideas. I really don’t wanna destroy my rpm 2 intake...
evilcw311
Most Evil Member!
Louisville, KY
Unfortunately heat will mess up the paint but it won’t mess up the metal. It will melt the permatex and you will be able to get it off.
Grab a friend. One person heat while other uses big flat bar to start separating and work your way around.
Sand the intake and repaint.
Problem solved.
Jerry santos
