Im planning a build and debating which route I could take. I know what I can make with the cheap route, I want to know realistic HP levels on this build.... Livernois 298CI shortblock Trick flow 2v heads blower cams (prob stage 2ish) Trick flow track heat intake Bullit oval throttle body On3 (I know the rep) 76MM ball bearing turbo kit. Any ideas a realistic pump gas and race gas HP levels? Depending on the potential there ill either go all out or go cheap and sit on 600-650ish.
Yeah Justin was making almost 550rwhp through his auto with an on3 kit and similar mods, except the TF heads. If you can get the Vbands situated you can make good power with them.
