Hydroboost Master Cylinder Options
ForeverDriven
Yo everyone.
I've been eyeballing the "cheap ass" 4-piston brembo upgrade, the ATS fronts and Taurus rears.
At this point my biggest question is the master cylinder. Pedal feel becomes a big issue, pushing all that fluid into 4 pistons. So I went to look at larger brake cylinders and just can't find anything about compatibility?
Anyone know the magic behind what can/cant bolt to a hydroboost system, or if we are stuck with the hydroboost master cylinder because its such a specific system?
If this gets too complicated, the 4 pistons likely aren't worth it. I don't want/need to order a custom bore cylinder from Willwood or anything like that.
If it turns out to be a crap setup, I've heard of swapping 05-9 calipers and Boss 302 13.94" rotors? Let me know about that too, if you got experience. Will be looking into it myself.
Thanks,
Blake
cobrajeff96
Germany
Depends on what generation hydroboost you're working with. You might find one option for the 94-95 boosters out there and I think it was Hydratech maybe. But the real options come with the 99+ hydroboost unit. For instance, I had to switch from a 96-98 booster to the 99+ which allowed me to get the Baer Remaster. Bear in mind that just because you get a new m/c with a bigger bore doesn't necessarily translate to the right pedal feel or ultimately the final brake torque. My recommendation would be to contact someone at Maximum Motorsports via their email and tell them your specs, then they can recommend you what size m/c bore to get. Because for instance the Baer Remaster can be had in I think three different sizes. Turns out the one I needed was the largest at 1-1/8" due to such massive caliper volume front and rear.
ForeverDriven
ForeverDriven
Good info! I thought the 94-95s were vacuum tho?
Either way, if Baer can shoot me a good cylinder, I'll definitely contact. Is Baer through MM?
I'll look into the different booster too. The only difference I've seen is the mount tho, how it hooks up to the pedal? Ik the firewall backet is slightly offset from the older version.
cobrajeff96
Germany
Yea, that's right actually. 94/5 were vacuum.
I don't believe MM has ties to Baer but it never hurts to ask.
There's definitely big differences between booster generations. Firewall clearancing is one of them, I had to slightly curl up the 11 to 1 o'clock position of the sheet metal. Not a big deal, took all of 15 minutes. But the stroke lengths are going to be different I think, and the pedal ratio on the foot box is also different. I remember I had to get a 99+ pedal box but it's a direct bolt in, you just transfer the brake and clutch switches across. And then there's the booster-to-m/c flange orientation. The 96-98 is vertical I think, and the 99+ is kind of diagonal so they are not compatible. To run a Baer m/c you can only run a 99+ booster. And finally the power steering port orientations are completely different on the two booster generations. Most people when they go this far into the deep end is to just go full custom AN lines like I did, otherwise you have to source OEM lines and mount it all up (if a junkyard doesn't pan out, I'm sure LMR or CJ and the link now sell them, and there's Rock Auto too that I know sells at least some of them). MM is going to be your best source of info as to how you put this all together and modify what's already there to make it all work... and work safely.
ForeverDriven
ForeverDriven
Great info. Good to know its a relatively known thing at least, if the firewall is bendable and a pedal box is easy pickings, I can look into it.
On a weird note, I wonder if I can have my current cylinder bored? I'm clueless about the intricacies but if that saved me the pedal box, new cylinder, and wack config, might be worth a look. Car doesn't have to run for a good few months.
LEGALLYFAST
Quick question. Is the hydro boost the reason brakes on the new mustangs seem so touchy at low speeds?
cobrajeff96
Germany
There could be more than just one reason a brake pedal seems sensitive, but my hydroboost setup(s) have worked very nicely with good pedal feel.
Mustang5L5
Due to how the MC is clocked, the corresponding MC will only bolt to the same year span hydrobooster.
96-98 Hydroboost MC is a 1" bore MC
99-04 Hydroboost MC is 1 1/16" bore MC
Baer Remaster MC is a 1 1/8" bore MC, but only bolts to the 99-04 hydro unit
To swap a 96-98 setup to 99-04 will require a new MC and hydrobooster, pedal box, and all the corresponding lines as the connection are different. Spendy, extensive project. The 99-04 setup would be better for ATS front/43mm rear setup, and the Baer Remaster would be more ideal, however that's a $500 MC and by the time you buy the other parts, this is a ~$1K project not including the cost of the brakes themselves. If oyu found someone willing to bore your MC, you will need to locate a corresponding piston to match. I'm not sure the 99-04 piston would drop in, but I would imagine no shop will want to touch that due to liabilities if a modified MC were to fail. I'm not sure I would want the liability of a modified MC on my own car.
I have hydroboost on my Foxbody (previously with ATS brembos) and a Baer Remaster, and the stock hydroboost setup on my '00. Neither are touchy at low speed. Both systems wear Cobra brakes and are fantastic for a street car. I have ATS brembos, but they sit on my shelf due to issues with rim clearance and the fact I don't want to toss them on a non-ABS car (fox) with not enough tire (245's) up front.
chrisp427
Texas
Looking at the pictures, this setup eliminates the need for the big huge booster? That’s what I want to remove from my 94GT but still have a good pedal.
cobrajeff96
Germany
The hydroboost unit replaces the vacuum booster, yes.
There's really no downside to the hydroboost aside from added complexity.
You'll want to email Maximum Motorsports. I know for sure that you'll have to do some slight tweaking of the brake pushrod hole in the firewall. It's not that bad, can be done in less than 30m with vice grips or a channel lock. But you will either have to source OEM or OEM-like lines which I think can be done through Rock Auto or you can make your own AN lines after buying all the threaded adapter fittings. Tons of vids out there on how to make the lines. Not much benefit to doing custom lines apart from lasting forever as well as looking trick.
Mustang5L5
Unless you need the space, it's not worth it.
I put hydroboost on my Fox. Lost of $$$, had to make myself custom lines, had to install a remote mount reservoir and replumb it 2 times.
The Hydro is sensitive to restriction on the hydroboost low pressure return. It needs to see minimal restriction otherwise the brakes drag. I plumbed mine like a 96-04 Mustang which tees the two low pressure lines (rack and hydro return) before a single return to the reservoir. Finally I split the returns and that solved my problem.
In the end, brake performance was pretty much the same. Pedal feel was probably a little firmer as I went with the Baer remaster which is a 1 1/8" bore MC vs the standard 99-04 MC which is 1 1/16". I wanted the larger MC for looks and for ATS brembos, but ended up sticking with Cobra brakes. If i could do it all over again, id at least would have stayed with the standard Ford MC with the smaller bore, but would have just left the original vacuum boosted setup alone.
