I need a 5.0 5 speed trans
supra mustang 95
My 95 mustang gt with toyota supra front conversion and I made my own gt40 style air vents
supra mustang 95
supra mustang 95
Thanks buddy it's done in the front now need to work on sides maybe make supra rear end maybe leave it idk yet also goin to try to fit fox body 2.3 trans wc behind my 5..0 my 2nd gear synchros is shot
07GtS197
Fort Myers, Fl
If you’re going to make the rear look like a Supra you’re better off getting one. At the end of the day it’s your build though.
07GtS197
Fort Myers, Fl
Price of admission is laughable for MKIV’s these days.
I figured as much after I wrote that. Regardless, I wouldn’t put the effort in. At the end of the day it’s still a Mustang under all that bondo and has the Mustang interior. But it’s not my project.
cre8d2go
NC
94-97 V6 mustang T-5 work and are somewhat easy to find. These are exactly the same as the later foxbody T-5. You have to use your 95 bell housing.
The problem is the input shaft on your 95 T-5 is different. They are specific to 94-95 only. Your best option is to order a rebuild kit and rebuild your T-5. They are easy to rebuild and tons of info on how-to is available. If you must change the trans, the other option is to find a 5.0 bell housing from a foxbody and the 94-97 T-5. It will push the shifter back a little.
