i need help!
Bianner
i'm posting this his here because i don't think anyone goes to the 4v specific section. well while i'm driving sometimes my car will bog down and not want to go then take off suddently. i think its my tps. what do u guys think it is.
its a 98 cobra
94MuStAnGGT5o
MAF sensor could be dirty or broken. My car had idling problems and when u step on the gas it didn't pull for a second. Cleaned the MAF and 2 other sensors on the air intake and car runs perfect now.
Try it it will only take 10-20 min. But be carefully not to drop the sensors as they are very fragile and expensive, also you spray carb cleaner in them and let them air-dry, that's how you clean them, after that you can reassemble. There should be better instructions on the net, check Google.
B
Bianner
i cleaned the MAF it idles better but it didn't solve the problem.
