I popped my hood today...
realitygt
and in the first injector hole there was coolant, just a little bit but it was still there. there's been a trail running along the inside of the head into the valley that i've noticed for about a year.
Since last year when I got all the fluids flushed the coolant level hasn't went down maybe 1/16 of an inch and is still way above the add coolant line.
it's an npi intake w/o aluminum crossover, could that be the problem? it looks to be coming from inbetween the 1st cylinder intake runner and the coolant crossover because there is a little bit of a whitish looking residue on there (nothing wet.)
LI98GT
Long Island, NY
Sounds like the beginings of the hairline crack and it could potentially let go at any time. I would look to change it out if I was you as soon as you can and change it out on your terms. You don't want to get stuck, requiring a tow if it does go at some point. I'm running PI cams and PI intake on a stock '98 tune with no problems with either idle, emissions or running - not saying it wouldn't be better with a tune, but the stock tune seems to handle the PI parts (atleast minus heads) just fine.
R
realitygt
thanks man. I might end up getting the livernois one then
R
realitygt
J.R. said:
No you won't, go see the mechanic and let a pro handle it.
wtf is stuck in your ass?
it may be a waste of money but I'll pay it for the convenience of it
jfor441
It's not anymore convenient than buying a PI intake, PI intake gaskets and getting the nipple.
reivaxtorres
about 80-90% of the 98GT's do not need the water pump nipple, as they are already equiped with it.
as far as needing a tune, no, you dont. i had the full PI swap and just about all the bolt ons you can think of (minus headers), and i was running fine on the stock tune.
justinschmidt1
your car will be fine with the stock tune...although it may idle a bit lower
Livernois is a waste from what I hear.
Jrgunn5150
It's especially a waste when you pay 500 bucks to do it the "right" way cuz it's all easy and it still leaks like that one guy's did :hammer:
phil_the_thrill
That's how my intake started to leak. Turned out to be a corroded gasket. PI intake is the way to go. No need for the livernois. It's not really any more convenient. I used RTV and a year later and 15,000 miles, no problems.
vermilion
maryland
people amaze me to pay way more money to change out something simple. im mechanically inclined and lazy but im shrewd with money first. i rather do it myself unless internal engine for warranty reasons. my .02. have a good day.
1996mustangGT
reality the livernois kit is a great way to go! i really like mine.
and justin if you dont even have the damn thing then how would you know about it?
i think the neverending batttle about this damn kit is getting old..
i got it. i payed 500 $ for it. so what? i just like having the plates more-so than the rtv...
anyways....
sorry to hear about that! thats exactly what mine did...then heading home one night it jsut fragged itself :(
R
realitygt
I read over on corral numerous times and once in a pi intake swap only thread that for all the 4.6 2v they all used the same waterpump and you won't have to switch out the water pump nipple
I just really don't want to rtv my heads.
jfor441
What is wrong with RTV? You are still using the PI intake gaskets. Just also using a bit of RTV.
Dws 95 mustang GT
