Important 4.6 dipstick ?....
Tomwas
According to my owners manual I appear to have a 3.8 oil dipstick... Shows the flexible cable type for the 3.8 and the solid metal one for the 4.6... Oil check not showing on dipstick... Wondering if they are different lengths... Don't want to run with no oil, want to see correct amount when checking....
07GtS197
Fort Myers, Fl
I believe the oem one was the flat one and aftermarket/revised perhaps one is the cable one. I had a flat/curly one in my 00 gt then a cable one when the motor was replaced. My 02 gt has a curly one too so I’ve had both.
On a side note, if you have to change the oil soon you might as well do so and put in 6 quarts to see where it measures on the dipstick and mark it as reference.
Kermit
I have a ‘97 Cobra convertible, bone stock with approx. 26,000 miles. Everything on it came from the factory, including a flat metal oil dipstick. So, maybe they had both as stock, depending on the bin they were pulling from.
RAU03MACH
NEW MEXICO
Any thing is possible . Ford dose e lot of different parts on there vehicles
I would not mind having the metal blade type in mine
The cable dipstick is a pain in the ass to read sometimes
If you get a part number let me know I may swap it
Akurma
Pennsylvania
my 1999 GT had the flat metal dip stick, I switched it out for the revised one for the 6qt oil fill
Tomwas
Tomwas
Was actually kind of surprised the 4.6 takes 6 qts.. Just seemed a lot although my two six cylinder BMW s take 7 qts... Both 2.8s...20200524_120239(0).jpg 20200308_174138_kindlephoto-37207816.jpg
07GtS197
Fort Myers, Fl
It was revised in I think 01 to 6 quarts from 5 because the pan could go dry during high rpm runs.
