Injectors for nitrous
sleepn_sn95
Indy
Hello, I was planning to run a 100 dry shot on my mostly stock motor until I can piece together a good h/c/i. I know I will need a WOT switch and window switch, a 255 lph pump, and all the other small things. My question is will I need to upgrade my fuel injectors? If so which should I get? Thanks
Musturd
I've ran a 125 shot on my car with stock injectors and a 255lph for a long time with no issues make sure to get to shades colder spark plugs tho.
LAFENATU
Why a dry shot..do you already have the kit? If you haven't done anything yet, I would do a wet kit.
I would do 24's if it were me but 19's would probably work ok, Musturd said he had no issue with a 125.
Musturd
For sure go with a wet kit. They are both really simple installs.
sleepn_sn95
sleepn_sn95
Indy
Alright thanks guys. And I should just keep my timing at the stock 10*?
Musturd
How big a shot you running ? For a hundred shot you should run it at 8 degrees. And get cooler plugs
